Page 2 of 2 FirstFirst 12
  1. Quote Originally Posted by m.marino View Post
    Have you looked at the Lathe in this video:http://www.youtube.com/watch?v=Y1IDHIcyHLY
    Michael
    Actually, this video was made nearly 4 yrs ago and since then no other videos came out showing some metal turning but plastic.
    If it was able to turn metal - builder would upload it for sure. Just makes me think is it not rigid enough???? not able to turn metal???
    Will you Jonathan treat us with some action video??
    Quote Originally Posted by wiatroda View Post
    Actually I think this lathe was purposely made to turn plastic.? I think the bloke is the same guy who makes Dumpster Anti backlash Delrin nuts but I could be wrong on that one thou I'm sure it was made just for plastic.!
  3. Quote Originally Posted by JAZZCNC View Post
    I bet you're right. never heard of those nuts. But it would be nice to see some fancy shape metal turning anyway :)
    This lathe has sat on the side doing nothing since I posted here, just not had time for it. A few days ago a 12Nm stepper motor arrived, which just so happens to fit the lathe mount, so how could I resist using it to power the spindle?
Name:	DSC09939 (Large).JPG
    A few moments later:
Name:	DSC09941 (Large).JPG
ID:	6948Click image for larger version.
Name:	DSC09942 (Large).JPG
    I had to take the covers off since now I don't have the right length belt which means the motor is in a funny place. I chose a 36:22 (motor:spindle) ratio since if we take the speed/torque curve from Zapp's site and convert it to more meaningful units, the peak power is around 600rpm so around 1000rpm spindle speed with that ratio.
Name:	12nm stepper power curve.png
    I've only got the motor on 70V (DM860 drive), so that graph isn't ideal, but it seems to work well and runs the spindle up to 2000rpm. The motor was fine with drilling a 6mm hole in aluminium and general turning. I think I'll make a bigger pulley for the motor and try it anyway. The finish leaves a bit to be desired, but I think that's mainly the lathe itself being weak and having to have the material quite far from the chuck as currently the rear shaft on the motor interferes with the saddle. I don't think that will be a problem with the longer belt and if it is I can easily mill a little bit off the steel block I attached to the saddle to get clearance.
    I configured LinuxCNC to run the stepper motor as the spindle by editing the .hal file - pretty simple. Next step is to get G33/G63 to work so I can do threading. I could just run it as an A-axis and program a ramp (e.g G1 Z-10 A10), but I'd prefer to do it properly...
    Anyway, it seems this thread is useless without a video, so here goes:
    Edit: Almost forgot to mention I solved the backlash problem on Z. Turns out it was just the belt being a bit loose, tightened it up and now the backlash is essentially zero - the 0.0001" indicator returns, as far as I can see, precisely to the same mark if approached from either direction.
    I just need to make one piece for the X-axis so I can put the second nut in to get the same result. I wonder where the Belleville washers went. I think I've broken the magneto bearings whilst working out what was wrong, so I'll buy some better ones. He's got 708A and 708C so presumably that's the different contact angles - it would be good to know which is which so I can get the ones that tolerate higher axial forces!
  5. #15
    Looks fantastic Great video mate
    Ralph Waldo Emerson
  1. Dyna mechtronics DM3000 lathe , mach conversion
    By dazza in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 12-12-2015, 04:35 AM
  2. Seig C4 Lathe CNC conversion
    By njhussey in forum Sieg Lathes
    Last Post: 11-04-2014, 06:40 PM
  3. FOR SALE: Axminister White Micro Lathe 2006
    By Fivetide in forum Items For Sale
    Last Post: 13-02-2013, 04:47 PM
  4. The sows ear, a Clarke Metalworker Mill / Lathe conversion to cnc
    By FatFreddie in forum Conversion Build Logs
    Last Post: 03-12-2010, 02:46 AM
  5. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 12:47 PM
