  1. Thanks for your reply.
    I don't think the ESS is the problem, I have tried again running mach3 in PrinterPort mode, and without any using any Motion Conrol, by Mach3 Menu > Function Cfg's > Reset Device Sel.., restarting mach3 and selecting No Device.
    I can still get the same error.
    As you say it's worth a try using an order version of mach3 for testing to see if I still get the error.
    But from what I have been told I can only use the ESS with Mach3 R3.043.062 and newer.
    Best Regards.
    "If first you don't succeed, redefine success"
    Quote Originally Posted by Mad Professor View Post
    Best Regards.
    No not true I've seen someone post he use's Version R3.043.022 for Mach and plugin v10fb1 for ESS on the Mach forum SS section.
    Edit: You must use R3.043.062 with the latest plugin but not the earlier plugins.
    Try re-installing Mach completely but don't install the PP driver.? It can be added at anytime if you do need it.
  1. "Hacking" and "Modding"
  2. VFD problems, please help. error code "DL"
    By humbo3d in forum Spindles & Drive Motors
    Last Post: 06-02-2014, 05:49 PM
  3. MACH 3 2010 Screenset Zeroing Macros
    By Washout in forum Artsoft Mach (3 & 4)
    Last Post: 12-01-2014, 01:15 PM
  4. Replies: 4
    Last Post: 28-09-2012, 12:06 PM
  5. "Racks" VS "ball screw"
