Thread: Advice: Timing Pulleys and Belts
24-06-2012 #5
Hmmm...
1:1 on to a 5mm pitch gives you a mechanical advantage of 1256:1
So 3Nm gives a driving force of 3 x 1256 = 3768 N
Question is, do you really need 0.37 tons to drive your Z? Using a 16mm screw suggests you are not lifting the bed.
Is it too late to change motors? I suspect you are severely limiting your top speed.
If you geared it 5:4 then it would half step .01 mm and quarter step at 5 microns which is my favourite, being the resolution of my digi calipers.
Ballscrews - pulleys - timing belts
By vre in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 15-01-2014, 08:03 PM -
Belts & pulleys,
By jcb121 in forum Belt Drive, Pulleys & TimingReplies: 4Last Post: 29-09-2012, 12:32 AM -
pulleys and belts - sizes
By mocha in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 22-07-2012, 05:16 PM -
Belts & pulleys & advice please
By CNCBlug in forum Belt Drive, Pulleys & TimingReplies: 12Last Post: 29-04-2012, 10:31 PM -
Source for XL timing belts and pulleys
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-08-2009, 01:21 PM
