Page 1 of 3 123 LastLast
    Bobp's Avatar
    Location unknown. Last Activity: 30-07-2012 Has been a member for 9-10 years. Has a total post count of 7.
    I have purchased the THC in the link below but have no idea how to wire it to either the 15 pin plug or 12 pin connector on the TB6560 driver board. If it would wire to the twelve in connector his would keep the plug free for a remote.
    http://proma-elektronika.pl/download/doc/thc_en.pdf
    3 Axis TB6560 CNC Stepper Motor Driver Board Controller | eBay
    Hope somone can help
    Bob
    I set mine up with the instructions i found on the mach3 forums. I did have to read a lot of posts though.. Im sure someone on here will be of help and has a good amount of information on the subject..
    From the looks of it you just take a wire from the UP/ARC/DWN connections on the THC device to a spare inputs on the TB board.
    The COM will go to the com or GND pin on the TB.
    Then in the control software setup the THC inputs for UP/ON/DOWN to the same pins from the TB.
    The + & - are power the THC device needs so come from a separate supply which by the looks of it can be anything between 5 & 35V I'd use 24V has it will better handle any noise issue's and quite cheap to find.
    That link to the TB doesn't show pin outs so can't help with telling you pin numbers unless you can find a link to the manual.?
    As usual you have it Jazz, here is an add from fleebay with some pics of the configuration at the bottom.
    http://www.ebay.co.uk/itm/Proffessio...item27c96d9824
    Bobp's Avatar
    Thank you both for your replies. I just don't know where to add the up down wires to the board as the only free connections are either on the 15 pin remote plug or the 12 pin connection just behind it which seems to be used to connect a dro. All other connection points are used up with motors, e stop and limit switches
    Ahhh i see, have you got a better picture of your TB 6560 as there are several variations:
    Such as the one above that dosnt appear to have the ones you mention behind the 15pin D
    This one clearly shows some spare inputs on the right..
    I know you have a Ebay picture listed but can you get a better picture of the terminals for me..
    Rick
    If all else fails and you have used all the inputs near the Estop input (there are 4 possible) then you may have to use the pendant input (15pinD) lets see what the pic tells us
    Rick
    Bobp's Avatar
    Hi Rick,
    It is the same as the one shown on the ebay link and any photo on the disc or manual is the same
    Quote Originally Posted by Bobp View Post
    Hi Rick,
    Have you fitted it to a machine and if so have you used any of the inputs where the E-stop input is shown in the add?
  1. Z axis height setter
    By phill05 in forum General Discussion
    Last Post: 29-11-2016, 01:14 PM
  2. FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
    By nobby in forum Items For Sale
    Last Post: 20-05-2014, 07:33 PM
  3. Plasma, Mach3, Sheetcam and a Proma Torch height controller..
    Last Post: 14-04-2014, 03:49 PM
  4. Height Mapping?
    Last Post: 26-10-2012, 11:40 PM
  5. Setting Z height with an ER32 collet
    By Robin Hewitt in forum Machine Discussion
    Last Post: 27-03-2010, 09:16 PM
