    Here's a topical but tricky question for the illuminatti that keeps coming back in various guises:
    Assuming the budget will not stretch to ALL of the following features, which one (or two) would you choose to compromise on?
    Welded steel framed gantry
    20mm alloy Z and Y axis
    Water cooled 2.2kw spindle and VFD
    M542 drivers
    50v power supply
    1610 ballscrews
    20mm supported rail
    variable height table
    There's only one and that's the table.!! . . . Some times people need to accept they can't afford to build just yet and save up a bit more.!
    99% More often than not if they do proceed before ready it does cost them much more in the long run. . :(
  3. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
    This isn't always a bad thing though if I knew how much the router was going to cost when I started I probably wouldn't have done it BUT I'm so glad I did!
    You don't count the cost on this one ;)
    Why would you want a variable table height? Seems to me that's just more hassle than it's worth. I'd just move the gantry up and down instead with dual ballscrew and slides if rigidity was that essential.
    I have toyed with the raising and lowering the gantry instead of just the spindle I should make a decision I guess lol since I want to start the ball rolling with making my mounts now.
    The biggest hassle for me is because I'm using toy electronics (Arduino, cncshield, cheap ass steppers) is I would have to wire 2 steppers to 1 socket so I can have a dedicated stepper for each motor not rocket science just hassle. Or Buy better steppers and wire them to the Arduino.
  5. #4
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Desertboy, is there any thread you've not pointlessly resurrected yet?
  6. #5
    It's because it makes suggestions in the bottom right corner and I never notice the dates lol. Rather than I'm trying to resurrect 5 year old threads
  7. #6
    i'll give my answer from a noobies perspective.
    welded steel framed gantry... i dont know if i'm understanding this wrong, but i see plenty of alu profile gantries even on here there are people using profile frames
    20mm alloy z and y axis, again not sure if i understand right, but if you mean the mounting plates then yes i'm looking this way myself and think it's needed
    water cooled 2.2kw spindle and vfd, personally i've not dug deep enough yet to find the answer to the power needed for most operations, but my understanding is if you dont start water cooled then you will end up here anyway, but as i said the power at 2.2kw is something i feel might be something you can compromise on, personally i'd been looking at 1.5kw
    m542 drivers and 50v power supply are both things i feel come down to your personal preference. your desire for speed will have alot to do with how much you want to spend on drivers and psu... me personally i keep telling myself i'm going to keep cost down by staying with cheap drivers.. the reality is that i will more than likely want to upgrade to better motors once i realise what i should have bought.. hey i might even get to the stage before i even buy my first motors..
    1610 ballscrews, now personally with loads of reading i'd already decided ballscrews were going to replace that original thought of using threaded rod.. however i'm not sure what the difference is between 1605 and 1610 yet and how they will apply to myself
    20mm supported rail is pretty much a given for the size of table i'm considering and maybe table size is what decides whether you go supported or not, the arguements here for supported rails really do make it hard for you to consider anything but them
    variable height table is something i never even considered i suppose a trade off would be to build a low table with the intention of packing it out everything you did any work that needed it raising, but then i imagine alot of our work is like this therefore i'll personally not even consider this yet
  8. The Following User Says Thank You to wilfy For This Useful Post:
  9. #7
    Quote Originally Posted by wilfy View Post
    Big cost saving advantage IE: 50mm x 3mm box section 7.5mtr length priced today £28 VS 60x60 Profile £25 per/mtr = £187.50 per 7.5mtr length.!! Then you'll need about the same again for the correct fixings to make best use of the profile.!
    If small machine using small cutters then 1.5Kww will be fine, larger machine cutting harder materials or larger cutters desired then 2.2KW much better option.
    Personal preference regards Drives/PSU doesn't really come into it regards speed.? . . Speed should not be thought about has been got from drives or motors but from the correct choice of screw pitch. Yes to get best performance from motors then voltage and therefore drives/PSU play a part but it's the screws and the relation ship with running motors in the right RPM range in conjunction with machine size and intended purpose or goals that make the difference between getting it right or wrong.
    Cutting corners regards drive quality or PSU size is THE most common mistake new CNC'rs make.!! . .. . . unfortunately it's mostly after weeks or months head banging they find out.!
    Simple really 1605 16=Diameter 05= pitch or distance traveled per rev. The net affect 1610 can go twice has fast for the same RPM but with less resolution per rev.
    You decide the best most suited for your intended purpose. With carefull screw choice to make best use of motor's Ideal working RPM range then you can tailor the machine to give the speeds and torque you require.
  10. #8
    see there is me misunderstanding the reason behind different sized motors. however when it comes down to running the motors in the right RPM range, is it really a case of buying the right motor if you got it wrong or can you make the wrong motor work for you if you are using belts and pulleys?
  11. #9
    Yes you can recover to a point by using belts but something has to be lost in the process.? IE: (These examples assume motors run at correct voltage)
    Too small motor regards torque will need to be geared say 2:1 but the screw speed is half'd so machine speeds are lower. Plus the motors are working harder and therefore the drives to achieve the same speed has correct motors would be, this shortens life expectancy.
    Supplying Higher voltage to motors will increase rpm's slightly but also create excessive heat and eventually damage the motors.
    It's possible to have too large motor.? Large motors like Nema34's run quite bit slower than smaller nema23's and RPM's can be too low for the ideal required machine speeds. Gearing say 1:2 will increase screw speed but torque and resolution is lost. Same applies regards voltage.
    The way gearing can work is if you match the screw to the motor.? In this case a lower or to high spec'd motor can be made to work in a way you'd like and still have the speed and resolution you want or happy with. This is done by choosing either a higher or lower pitch screw than other wise would be chosen if the ideal motor/screw combo was available. . . BUT. . Still the same torque/resolution loses/gains applies just now your using them to your advantage.!!
    Just know that selecting the right motor/drive/voltage/screw in the first place can't be beaten and gearing to make some short fall up always comes at a price.!!
  12. #10
    I'd already consider M542 drivers, 50V PSU and 20mm round rails a compromise for most machines. Any of the things listed are a compromise for some machines.
    Also most of this depends on the size of the machine and the application, so it's not really possible to answer anything other than what Jazz has just said.
  1. Nitrile O-ring belt drive - suggested stretch percentage..?
    By Wal in forum Linear & Rotary Motion
    Last Post: 13-05-2014, 11:49 PM
  2. Commercial Machine choices...
    By jashington in forum Marketplace Discussion
    Last Post: 10-10-2013, 10:38 AM
  3. Drowning in choices for my plasma table project
    By SemiSkilled in forum Plasma Table Machines
    Last Post: 22-09-2013, 07:10 PM
  4. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
  5. Choices ...
    By Wobblybootie in forum Computer Software
    Last Post: 13-01-2010, 03:22 PM
