04-08-2012 #11
04-08-2012 #12
No apologies needed only a few days ago I didn't know it was called Compo untill asking clock makers what they used.!! Compo thou is just CZ120 brass which is engraving brass and what I was looking to buy anyway.!
Not unusual for me to cut expensive pieces of metal thou must admit I'll not be walking away from this one.!!
Edit: Recently I've had a death in the family and can you believe this job is to repair a Grave stone that got vandalised weeks after funeral.!!. . . Some Evil Bastards and If I catch them they'll be in a shallow unmarked piss hole.!! (After I've strapped them to machine and fly cut there faces and distinguishing marks off before they take there last breaths. .
04-08-2012 #13
Better Metal Stores in Alfreton are a good source for small amounts of sheet, bar and profiles in most materials (metals and plastics) but they are probably pricey, but a useful supplier nonetheless.
Proops Brothers in Fleckney have 3mm sheet 250x500 (mm) for £35, but I don't know the grade. They also have a lot of cheap (and cheerful ?) bits for small engineering.
TTFN
Rob
04-08-2012 #14
04-08-2012 #15
04-08-2012 #16
John S - the days of getting a 4'x4'x1/8" for £120 are long gone ( especially in CZ120) I just got a sheet 4'x2'x1/16" and the best deal i could get in CZ120 was £85 + vat - after a HUGE amount of shopping around.
Best Regards,
David
04-08-2012 #17
04-08-2012 #18
Made two of these a while ago.
16" diameter, 6" deep and two sit back to back and offset, that's what the small cut away's are for. The slots hold carbide inserted blades and overlap very slightly so the whole 12" is covered by blades.
This assembly then runs at 7,000 rpm in an industrial pencil sharpener.
To be honest can't remember what the alloy cost but I know it was pucker time when machining.John S -
04-08-2012 #19
PM replied to.
04-08-2012 #20
Damn John that's neat work. We are making rollers from 17-4 PH stainless for a local maltings - 380 dia x 180mm wide. You always have that moment where you wonder if it could all go seriously wrong and mess up £600 of material. Do you ever work with any exotic materials like monel or inconel?
Regards,
David
RFQ: I need apx 100 brass tubes being cut down
By Chance1234 in forum Projects, Jobs & RequestsReplies: 0Last Post: 02-04-2014, 02:05 PM -
Source for 0.5mm CZ120 brass?
By Hauk in forum Metalwork DiscussionReplies: 3Last Post: 10-03-2014, 01:36 PM -
Engraving brass
By Philly in forum Machine DiscussionReplies: 3Last Post: 03-08-2013, 10:09 PM -
3mm sheet brass
By cropwell in forum Marketplace DiscussionReplies: 1Last Post: 17-10-2012, 09:55 AM -
drilling brass?
By irving2008 in forum Metalwork DiscussionReplies: 23Last Post: 04-08-2012, 03:56 PM
