Thread: My garage
Irving, where did you get the info for calculating heat loss/heating requirements?
19-08-2012 #2
Ummm, one of the civil engineering websites... IHeat Loss through Building Elements due to Transmission
but when I googled I also came up with this: Heat Loss Through Enclosure Walls Equations and Calculations - Engineers Edge which I've not tried to see if it gives the same answer.
Also I found stuff on the concrete supply industry website..
I was doing the calcs for my own proposed workshop and 75mm on the walls, 100mm in the roof and a DPC in the floor are almost essential... I reckon my 6m x 4m build (no up n over door and double glazed, with uPVC personnel door) will require only 600 - 800W to maintain temperature. Given I only have a 32A breaker on a 20A feed I don't want to be using 12A for a 3kw heater.. i want to be able to power everything with some margin. I also plan remote heating control so I can maintain a background temperature in there to ward off condensation and remotely bring it up to working temp fairly quickly
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
How I almost set fire to my garage...
By cncJim in forum General DiscussionReplies: 26Last Post: 07-02-2014, 11:51 AM -
shed/garage electronics,
By jcb121 in forum General ElectronicsReplies: 12Last Post: 29-07-2013, 10:52 AM
