Thread: Laser cutting 10mm acrylic?
03-09-2012 #14
No problem Hugh.
Can pick you up as before, just let me know.
They are very very easy to use, easier than a CNC mill, no tooling worries for a start. You select either engrave or cut and the speed and power and that's basically it.
One hours training is virtually all you need, after that it's a self taught learning curve of the settings for different materials but easy enough to get a library sheet printed out.John S -
The Following User Says Thank You to John S For This Useful Post:
Acrylic Cutting Help
By Tenson in forum Machine DiscussionReplies: 26Last Post: 08-11-2016, 08:15 PM -
Laser cutting Machines
By Want2build1 in forum Laser Machines & BuildingReplies: 44Last Post: 13-05-2014, 01:58 PM -
RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
By nobby in forum Projects, Jobs & RequestsReplies: 0Last Post: 29-04-2014, 12:36 PM -
RFQ: RFQ.. Acetal or acrylic... laser cut or routed.
By purpose in forum Projects, Jobs & RequestsReplies: 2Last Post: 12-12-2013, 12:03 PM -
laser cutting ally plate
By i2i in forum Tool & Tooling TechnologyReplies: 12Last Post: 21-02-2013, 08:47 AM
