    thanks again for the help, starting to make my way around this now. having a bit of trouble snapping 2 pieces of the box section to it's self, but i am finding the by placing measure lines i can snap to them then just delete them.. same goes for scaling.. i'm measuring out the size i want and then snapping the item to the line to get the right size.
    i am struggling at the moment to find a source for sbr16 rails and bearings and also a suitable ball screw assembly that i can make to size.
  2. Hi Wilfy,
    Quote Originally Posted by wilfy View Post
    I have SBR## & RM1605 screws and BK/BF12 drawings and data sheets. I've posted the data sheets, if the skp file are needed I'll pm them to you.
    Cheers,
    Geoff.
    Attached Thumbnails Attached Thumbnails SBRxxUU.pdf   BF xx Floating Bearing.pdf   BK12.pdf   BK12+Machining.pdf   BF12 Machining.pdf
  1. Sketchup
    By mekanik in forum Sketchup
    Last Post: 06-11-2013, 09:34 PM
  2. Just a thought, a google map of member locations
    By D-man in forum General Discussion
    Last Post: 09-04-2013, 02:38 AM
  3. Google Sketchup >> Vectric VCarve
    By kingcreaky in forum Computer Software
    Last Post: 09-03-2013, 07:42 PM
  4. Google Sketchup components?
    By mocha in forum Sketchup
    Last Post: 07-08-2012, 11:49 AM
  5. Converting sketchup to dxf
    By motoxy in forum Sketchup
    Last Post: 08-07-2012, 12:04 PM
