Thread: Time to go vertical.!
I think the short answer is "it all depends". clearly the ideal(ish) option is for the gantry to traverse horizontally in X so the Y is vertical and only the cutting head/Z-axis has to be lifted against gravity, but then you lose the benefit of having the chips fall into clear space. Unless your X-rails are space out from the bed in some way.
Of course, you shouldnt be running near the stall point anyway, there's a high chance you'll lose steps on fast direction changes if you do...
Vertical router design
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 29-03-2014, 10:43 PM -
Why not vertical?
By irving2008 in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-09-2012, 07:20 PM -
Vertical Machining Center Info
By benkat in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 13-04-2012, 03:12 PM -
axyz vertical cnc router
By flanagaj in forum Manufacturer NewsReplies: 0Last Post: 30-12-2011, 10:39 AM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
