I remember John S told be in no uncertain terms that a 4" chuck is too much for the C1 lathe, so your 3" chuck sounds like the best bet. I'm currently loooking for an 80mm 3 or 4 jaw self centring chuck for mine since the one I have didn't come with the external jaws, which is exceptionally annoying.
Could you hold it between centres?
05-10-2012 #2
Thanks for the offer irving, but if Jonathan thinks it would be to much for the lathe then I'll take his advice.
I do hold it netween centers but its not always inline I tried the method may Dad suggest , marking the center holding againt the point then tighting the chuck it works to some extent but sometimes it out and the vibrations not doing the Lathe anygood I think. They are to thick to fit through the chuck so I can round one end off.
Ralph Waldo Emerson
05-10-2012 #3
No that's not what I meant. The 3" chuck irving has is good, but the 4" one he linked to would be too big - so buy his 3" chuck asap as that's a very good price and work out how to make the backplate! It's easy to make a chuck key...
Round one end off with it between centers then use that end to hold it in the chuck as normal? Unless you need to machine the whole length in one pass that should work...
FOR SALE: Axminster Drill Clamps - buy one get one free
By EddyCurrent in forum Items For SaleReplies: 3Last Post: 26-04-2014, 02:25 PM -
WANTED: Boxford 125TCL Chuck Wanted
By JAZZCNC in forum Items WantedReplies: 8Last Post: 01-02-2013, 12:51 AM -
4th Axis timing pulley + Axminster bandsaw review
By Jonathan in forum Metalwork Project ShowcaseReplies: 4Last Post: 09-04-2011, 07:31 PM -
Axminster RF31 Milling Machine CNC conversion
By 1113562 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-03-2010, 12:42 AM -
axminster mills
By richb77 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 22-10-2008, 05:02 PM
