    Thanks for your replies chaps.
    Your comments Martin54 reinforce my concerns. I think it safe to say the idea of using a threaded bar has been scrapped. Now to find a supplier of pulleys and belts..... I found Zapp Automation (http://www.zappautomation.co.uk) are they good? Are there any better ones available?
    WRT "business use" It would only be used to prototype, I get my parts laser cut commercially, but need to do so in quantities of 100+. When first creating a new product it would be good to do a short plasma run and try things out before committing to a lasered batch. Getting it wrong with the laser is a very gutting experience, one I would rather not do again..
    But my business is one where I sell products when they are completed, I rarely have customers waiting and do not take commissions, which is nice as there is no additional pressure...
    Ricardoco, that is a cool bit of kit. I didn't know they were available, but can see the benefit and for a reasonable amount of money too. cheers for the link!
    Danny
    Quote Originally Posted by gr8fun View Post
    I have no idea how different suppliers or components compare, but I recently got my belts and pulleys from 5mm HTDŽ Timing Belts [4575] : Beltingonline.com, Supplier of power transmission and conveying products based on a pointer from somewhere on this forum, and was more than happy with their service.
  3. The Following User Says Thank You to WandrinAndy For This Useful Post:
    Quote Originally Posted by WandrinAndy View Post
    As was I andy, and i got my pulleys from here:=
    Pulleys - Timing Pulleys
    Im sure there are many alternatives but i asked sometime ago on this forum,and they were the most popular suggestions.
    Incidently they do chain and sprockets on Belting online as well..
    Rick
  5. The Following User Says Thank You to Ricardoco For This Useful Post:
  6. #4
    Ohh and they are about 5 miles away, just down the M27.... and half the price of zapp automation for the belts and pulleys. Thank you!!
    Quote Originally Posted by Ricardoco
    These guys do some great prices on bearings too (their belts and pulleys are competitive as well) - VERY handy.
    Much appreciated
    Danny
  7. #5
    Much appreciated
    Bearing station's prices on the timing pulleys work out better than beltingonline by the time you include VAT and delivery, although if you've not got a lathe to bore them it may be worth paying the extra and using beltingonline.
    You're not going to get anywhere with 8mm threaded rod. Even if you use pulleys to have a high ratio between the motor and screw, to compensate for the low pitch, you're still not going to get a very good speed because the efficiency of the drive system is so low. Driving the X and Y axes with a belt directly may be the way to go since the forces on the head are low, so the lack of rigidity with this system isn't such a big deal so long as the gantry is quite light.
  1. RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
    By HankMcSpank in forum Projects, Jobs & Requests
    Last Post: 17-04-2013, 07:35 PM
  2. FOR SALE: CNC Plasma Cutter For Sale
    By billm in forum Items For Sale
    Last Post: 17-07-2012, 07:50 AM
  3. Which Plasma Cutter to buy?
    By AndyG in forum General Discussion
    Last Post: 02-12-2011, 09:34 AM
  4. cnc plasma cutter problems
    By oadamo in forum General Discussion
    Last Post: 21-06-2011, 09:28 PM
  5. First Plasma Cutter
    By antsals in forum Plasma Table Machines
    Last Post: 16-05-2011, 07:58 AM
