Thread: Press cost question ?
Do you have a rough design of the cups, we can see? I don't know what you mean by modular (showing my thickness).
28-11-2012 #2
I dont know what i flypress is Jonathan but a quick look on google and yes that would be ideal , its only 3mm ali. I thought of milling one out of steel and then pressing the Ali into it. If they turn out to be good and I can make a profit hopefully i can sell some more :)
Yes I had thought of making some circular cups ( would be really retro) as well, maybe cheaper, not sure though I'm looking for the path of least resitance atm lol
Just hollow earphone cups , I must have 5 pairs in a box jointly costing £300 broken, I suppose I could try and fix them but thats not my point. oscar modular is when you can break it down into smaller pieces and replace the piece easily .. really with standard equipment, say for instance the jack and cable, if you break it normally its hard wired into the earphone, but if it is designed with a Jack at each end and socket on the earphones you can simply buy an off the shelf lead and your back to normal. You can also go from standard earphone plug to RCA if you want, same thing if you have a microphone.
Ralph Waldo Emerson
WANTED: Drill press
By D-man in forum Items WantedReplies: 0Last Post: 30-08-2013, 07:45 AM -
Plasma, guillotine and press parts available, specialising in low volume
By matttargett4 in forum Opportunities Available & SoughtReplies: 1Last Post: 03-01-2013, 01:04 PM -
Bearing interference fit / press fit
By Mad Professor in forum General DiscussionReplies: 5Last Post: 30-09-2012, 11:26 PM -
RFQ: small, primitive Press with cutting and bending capability
By Noel.C in forum Projects, Jobs & RequestsReplies: 15Last Post: 29-05-2012, 11:37 PM
