    Try giving Roland a call, I am guessing that if they do still have a power supply it will be expensive. Never dealt with them myself but have read on other forums that their technical department can be very helpful.
    8086's Avatar
    Lives in London, United Kingdom. Last Activity: 19-12-2012 Has been a member for 9-10 years. Has a total post count of 10.
    Quote Originally Posted by martin54 View Post
    I actually had to call them about a missing PSU for a keyboard once. They were very helpful, but like you say, expensive. For now I have replaced the power socket with screw terminals and semi-permanently attached my power supply.
    Last night I bought a DB9->DB25 serial converter and a LPT cable from Maplin, unfortunately neither worked, the LPT probably because I wasn't configuring it correctly on the PC, and the serial because they use a non-standard wiring. So I made a serial cable with things I had around already and hey presto! So now I have a PC interface working for it, and can move it around. I am planning to buy a dremel 4000 and the dremel drill press/vice thing, and make a part to attach to the carriage that used to hold the electromagnet that put the pen down. Will update as I go - should I make a build thread somewhere else or just use this one?
  1. Robin's smt Pick and Place build
    By Robin Hewitt in forum DIY Pick & Place Build Logs
    Last Post: 03-01-2015, 01:55 PM
  2. Brians Pick and Place Project
    By briand in forum Pick & Place Machines
    Last Post: 08-02-2014, 04:45 PM
  3. JuKu's pick and place project
    By JuKu in forum Pick & Place Machines
    Last Post: 09-12-2012, 08:42 PM
  4. FOR SALE: MAMIYA ECM85MK2 Pick Place
    By pdl in forum Items For Sale
    Last Post: 06-10-2011, 01:20 AM
  5. Pick and place log
    By Robin Hewitt in forum Pick & Place Machines
    Last Post: 22-10-2010, 03:00 PM
