Thread: Lathe / Milling for dummies
Many thanks for the reply. very much appreciated. Il have a go at removing the actual taper later.
04-12-2012 #2
It should be held in by a draw bar screwed in to the taper. Unscrew the draw bar about an eigth of an inch.,
Pull up on the drillling handle then whack the top of the draw bar. I use a sledgehammer. The idea is that the thread will catch the taper so don't unscrew too far.
You may need a new draw bar for the new chuck because they come with various threads.
BUILD LOG: CNC for dummies...Some electrics advice please...pretty please...
By andy586 in forum DIY Router Build LogsReplies: 6Last Post: 01-06-2014, 11:13 AM -
RFQ: Dublin, IRL Manual milling & lathe work required
By 250rri in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-01-2014, 01:07 PM -
RFQ: Looking for Aluminium CNC Milling Service + Lathe Work (2 Separate Jobs)
By biketrialsdave in forum Projects, Jobs & RequestsReplies: 2Last Post: 19-02-2013, 04:06 PM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM -
RFQ: Cnc for dummies
By MIAPISH in forum Projects, Jobs & RequestsReplies: 11Last Post: 31-03-2010, 07:33 PM
