    I actually think things are pretty good the way they are at the moment but that's obviously just my own opinion. At present people are required to think a bit for themselves & if they are not prepared to do that then they get no where which is probably where they deserve to be. Sorry if that is a bit blunt but you learn nothing if everything is done for you & at present people are certainly encouraged when they show a bit of effort themselves.
    It's a steep learning curve but right from the beginning you start to learn just by reading the build logs of others, using software to design your machine & the help & support you get from others on the site.
    There are already loads of designs available for free or to buy so why create another one & all the problems that go with that. From what I have seen in the short time I have been here there are quite a few experienced members who could already design & build machines that are far better than some of what is available already. There are already members who will help with cutting parts for anyone who asks.
    Quote Originally Posted by martin54 View Post
    to an extent thats very true you do learn a lot, but i find a lot of the logs i read get so far like basicly to the point of where they have enough help, and then that person never updates the log to show the machine finished and also the accuracy of the work coming from said machine.. yes its a generalisation and it's not aimed at everyone but there are certainly a lot of build logs that leave you wondering if they ever got finished
    Quote Originally Posted by wilfy View Post
    I often follow up folks I've helped who go quiet and You'd be surprised how many don't actually get finished due to circumstances and general life getting in the way. Thou lots are just having too much fun and can't be arsed to update.
    i dont deny that for one minute and i'm not saying it's a bad thing either at the end of the day you make the machine, it works, you forget to take pictures, you then get busy and spend more time designing parts to cut on your cnc and either dont have the time or forget that you didnt finish the build log.. i have to say i'm guilty of this from when i started making homebrew and for that reason i want to stick around here after my machine is finished and try to help people not make the same everyday mistakes, but also to showcase my build as best as possible to give hope to people that it can be done.
    one thing i've never found though jazz is your build log
    LOL, when I first started searching build logs, I tried to find his log too because when he helps so many with designs errors, you would think his machine will be the almighty. but as you read on about him helping using his machine as examples, you get a mental image of this ali cutting beast, with a stair lift beam gantry, steel box section frame, large motors with pulleys and long belts , interchangeable mdf, ply and ali beds, oh and 5mm pitch screws. Sounds like a strong machine with an unconventional gantry. Put our imaginations to rest. Pics please.
    Adil
    Quote Originally Posted by Iwant1 View Post
    NO NO NO NO you don't want to see my beast it's certainly a case of "Do Has I say not what I Did" and it's rough ready engineering at it's best. To be honest it's on it's last legs and in need of some TLC which it will get this year and possibly get turned into a plasma cutter.?
    Here's a pic of my son in early days doing his "I'm a little tea pot" routine. .
    Whats the secret ingredient Jazz-that sheet of mdf lurking in the background? G
    How did you screw the hiwin guides to the square profile?
    Thats because it got removed with my first BAN . . .
    LMFAO.... Such a naughty boy!!!! you mean they didn't just edit out the bits that were against the rules...lol, or maybe your design was against the rules... not conventional enough... Sorry Couldn't resist..
  1. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  2. BUILD LOG: My first project: A fast router...
    By Boscoe in forum DIY Router Build Logs
    Last Post: 14-08-2013, 09:34 AM
  3. Project CNC Router for all
    By Anónio Pinho in forum Open Source Designs & Plans
    Last Post: 30-06-2012, 01:31 AM
  4. NEW MEMBER: New to MyCNCuk
    By m1ptr in forum New Member Introductions
    Last Post: 28-03-2012, 02:47 PM
  5. Replies: 1
    Last Post: 01-01-2012, 12:34 AM
