Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    Also there is nothing connected to the 'enable' terminals?
  2. #32
    yes ill take terminal covers off , the x any y motors are bigger than the z, i first got it with all the same motors , and sthing in the control unit arced out on the ox , so when i tok it back he up graded the the drivers ect and changed the 2 motors ,
  3. #33
    hold fire.. i'm gonna draw you what jazz is on about.. it's a really simple fix for you trust me
  4. #34
    pul+ dir neg
  5. #35
    Quote Originally Posted by 2e0poz View Post
    Doesn't need to be either leave them disconnected for now.
  6. #36
    wrong pul + dir +
  7. #37
    i hope you can read this as i've had to compress it
    let me know if you dont understand
  8. #38
    Better details in the manual here
    Stepper Motor Driver 4.5A, 50V CNC Microstepping
  9. #39
    so just moving both ends of the link wire to the left one terminal ?
  10. #40
    Quote Originally Posted by handyoodman03 View Post
    wrong pul + dir +
    Ok really this needs checking all the way back to the breakout board (Board with cable to parallel port)
    EDIT: Forget what I said after 2epoz posted that link and seeing the breakout board then it's wired correct for that board.
    Going to PM you my phone number so we can chat sometime because without all the details then things could go wrong and easily blow a drive.
    Shouldn't be difficult to sort but it does need all wires checking from the beginning and trying to do this via forum is asking for trouble.
  1. Stepper wiring/colour coding
    By rwb97 in forum Stepper & Servo Motors
    Last Post: 23-06-2014, 11:34 AM
  2. Replies: 1
  3. CY or SY cable for stepper motor wiring?
    By Jonathan in forum General Electronics
    Last Post: 26-09-2010, 06:25 PM
  4. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
  5. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 10:15 AM
