    hi everyone
    i am new to cnc. i live in bristol started to build my own machine in jan 13 just a few more bits to get and i will be up and running. if i can i will post some pics
ID:	8579Click image for larger version.
    What are you planning on cutting with it and what bearings have you used on the ballscrews?
  3. The Following User Says Thank You to Jonathan For This Useful Post:
    Quote Originally Posted by uppy121 View Post
    hi everyone
    i am new to cnc. i live in bristol started to build my own machine in jan 13 just a few more bits to get and i will be up and running. if i can i will post some pic sClick image for larger version.
    Well welcome to the forum and you get a thumbs up from me because its in your house!! looks like your almost there, i look forward to seeing your pictures and your progress, And again welcome.
    Rick
  5. The Following User Says Thank You to Ricardoco For This Useful Post:
  6. #4
    i will be cutting ply ,mdf, softwood, and yes it is in my front room good job i live on my own
ID:	8582   Click image for larger version.
ID:	8581   Click image for larger version.
  7. #5
    That's good, since the machine will just be able to cut those, but nothing harder. I asked because there are a couple concerning things about your current design:
    The unsupported rails on two of the axes will significantly reduce the rigidity of the machine, see here for a detailed explanation as to why. To start with you might as well try the machine with them, but I'll be surprised if you don't swap them for supported rails in a few months.
    It looks like you haven't put any angular contact bearings on one end of the leadscrew and that you're possibly using the motors to resist axial forces on the screw? If so you need to change this before running on the machine, as standard 'deep groove' bearings are not designed to work with axial forces, so they will quickly fail in addition to adding end-float to the screw. If you use a pair of angular contact bearings that wont be a problem. Look up the standard end-machining for ballscrews and it should be fairly obvious how to proceed.
    What pitch screws have you used on the longest axis and how long are they? The critical speed/whipping might be a problem.
  8. The Following User Says Thank You to Jonathan For This Useful Post:
  9. #6
    Splendid stuff :)
    nice and warm inside
    looking at you Y axis, the rails look unsupported which may lead to some problems over such a large distance
    they will be like guitar strings when you get going (maybe bass guitar strings )
    If it turns into a problem it looks like a supported rails would fit right in there without to much heart ache
    EDIT: oops, Jonathan beat me to it
  10. The Following User Says Thank You to blackburn mark For This Useful Post:
  11. #7
    Welcome local chap...
    shooting him down in flames already? Don't listen to them, you got this far without em. It would cost you thousands in training to learn what you have so far. Just get on and enjoy what your doing and keep on learning
  12. The Following User Says Thank You to Swarfing For This Useful Post:
  13. #8
    Hi, wellcome. Built in your living room - thats great. At least you wont have any rust problems. Reminds me a bit of a WI competition that my wife entered a few years ago. In answer to the question "what is the most useful item in your kitchen" she put " my husbands bandsaw". I had a machine for several years, unsupported rails, rack and pinion drive etc., but it worked well for me as I only cut mdf and ply. As Swarfing said just enjoy it. G.
  14. The Following User Says Thank You to GEOFFREY For This Useful Post:
  15. #9
    thank you i will be building a second machine and i will take in your advice on the bars so all advice welcome all i have to do is sell a few woodworking machines and i will start buying some more parts thank you all very much
  16. #10
    Quote Originally Posted by Swarfing View Post
    Excellant work uppy. You'll have great fun learning, much the same as I am at the moment. Make sure you keep us posted with your build photos!
  17. The Following User Says Thank You to kingcreaky For This Useful Post:
  1. NEW MEMBER: New to this forum, bristol
    By roygbiv in forum New Member Introductions
    Last Post: 08-01-2011, 04:01 PM
  2. NEW MEMBER: Hello all!!, Bristol England
    By Danimal in forum New Member Introductions
    Last Post: 10-09-2010, 09:31 PM
  3. NEW MEMBER: hello everybody, Bristol
    By HypnoToad in forum New Member Introductions
    Last Post: 09-09-2010, 12:11 AM
  4. NEW MEMBER: Hello from Bristol
    By matthewh101 in forum New Member Introductions
    Last Post: 10-11-2008, 12:13 AM
  5. NEW MEMBER: New Member - Bristol UK
    By spyder.boy in forum New Member Introductions
    Last Post: 05-10-2007, 09:33 AM
