Thread: Upgrade? Chinese CNC Machine
04-04-2013 #1Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
04-04-2013 #2
Rick,
Yep gettin' there, just uninstalled, rebooted, re-installed, rebooted, re-setup Mach3, rebooted, loaded the g-code for the 100mm X line and the 100mm Y line and get 102mm on both. . .
used stock settings of 400 steps, 2000 velo, 200 accel for both X&Y, Z is 400s, 700v, 100aLast edited by Carlb1058; 04-04-2013 at 01:51 AM.
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
04-04-2013 #3Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
04-04-2013 #4Cheers
Carl
04-04-2013 #5
The eBay listing indicates he has 4mm pitch screws and 20 turns moved it 80mm, which also indicates 4mm pitch screws as 80/20=4mm. So nothing to worry about.
The voltage readings are strange - should have got 5V or 0V, but nevermind as we now know they're set to 1/4 microstepping.
04-04-2013 #6
I didn't get anywhere near 5v, the readings I got were after atleast a dozen tests the first few were around the 2.7 - 3.2 range and they slowly dropped until they stayed pretty static at 2.2 - all three chips did exactly the same thing.
I wonder if it's worth just throwing an extra 90 bux at it for a board with dip switches etc?Last edited by Carlb1058; 04-04-2013 at 10:04 PM.
Carl
04-04-2013 #7
NO.
If you are going to throw money at it get the separate drives.
More reliable and if one goes down you can replace it, if one of those Toshiba boards goes down the whole lot is toast.John S -
04-04-2013 #8
Hey John I agree those boards are rubbish, what would you suggest he gets remembering his budget?
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
05-04-2013 #9
Like this? 3x M542 CNC Stepper Driver For Nema17 Nema23 Nema34 Motor +5 Axis Breakout Board | eBay if so that'll be a doddle, her who must be obeyed should only hit me two or three times at that money
plus that means more money for longer screws etc as I want to build a bigger one now!!
Carl
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
