Thread: Do such endmills exist?
	04-04-2013 #1Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
	04-04-2013 #2Yes, but those 'other way' cutters tend to be very expensive...to give you an idea, the 3.175mm shank drills I use (which are perfectly fine) are about 60p each....
 10pcs 0.8mm/ PCB Print Circuit Board Carbide Drills Bit End CNC Jewelry | eBay
 ...not much heartache when one of those snaps, but a 6mm shank/0.8mm dia drill....well, if it even exists, I'd be a broken man if it snapped!
	04-04-2013 #3
	04-04-2013 #4well if I had a lathe I'd just buy some cheap large dia. endmills & turn the shanks down to 1/8" (as it goes I did have a mini lathe but I spent more time fixing it than using it - it got sold!)
  FOR SALE: Dormer S259 Endmills for sale, 12mm 10mm 8mm 6mm solid carbideBy davy in forum Items For SaleReplies: 4Last Post: 10-11-2012, 05:55 PM
  Chipload and DOC for small endmillsBy Jonathan in forum Tool & Tooling TechnologyReplies: 15Last Post: 16-01-2011, 04:12 PM
  Secondary Kress spindle mount.. Does it exist?By fasteddy in forum Kress Milling MotorsReplies: 6Last Post: 18-08-2010, 05:25 PM
  Does such a beast exist (using Z plane as manual-esque drill press)By HankMcSpank in forum Computer SoftwareReplies: 0Last Post: 04-03-2010, 05:36 PM
