Thread: Do such endmills exist?
	04-04-2013 #1My modest spindle, has several collet sizes up to 6mm, but frankly swapping collets is quite time consuming (n comparison to just swapping a cutter out)
 99% of the time, I use a 3.175mm (1/8") collet....but occasionally, I need to use 3.8mm to 5mm endmills...to save me having to swap the collet out, I was wondering if anyone has seen endmills that have a cutting diameter wider than the shank (therefore for example 4mm cutter on a 3.175mm shank).
 yes, I know there probably wouldn't be much demand (on account such a cutter would be weaker than normal), but I only make light cuts on acrylic acrylic, FR4 & the time savings for me would be a massive win.
 I'm not even *that* fussed about precision (I typically use the larger cutters to skim a bit of depth of some material), so had even thought about getting a 4mm standard endmill turned down so the shaft is 3.175mm etc.
	04-04-2013 #2Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
	04-04-2013 #3There are pcb drills like that so I guess there are probably endmills too. G.
	04-04-2013 #4Yes, but those 'other way' cutters tend to be very expensive...to give you an idea, the 3.175mm shank drills I use (which are perfectly fine) are about 60p each....
 10pcs 0.8mm/ PCB Print Circuit Board Carbide Drills Bit End CNC Jewelry | eBay
 ...not much heartache when one of those snaps, but a 6mm shank/0.8mm dia drill....well, if it even exists, I'd be a broken man if it snapped!
	04-04-2013 #5
	04-04-2013 #6well if I had a lathe I'd just buy some cheap large dia. endmills & turn the shanks down to 1/8" (as it goes I did have a mini lathe but I spent more time fixing it than using it - it got sold!)
  FOR SALE: Dormer S259 Endmills for sale, 12mm 10mm 8mm 6mm solid carbideBy davy in forum Items For SaleReplies: 4Last Post: 10-11-2012, 05:55 PM
  Chipload and DOC for small endmillsBy Jonathan in forum Tool & Tooling TechnologyReplies: 15Last Post: 16-01-2011, 04:12 PM
  Secondary Kress spindle mount.. Does it exist?By fasteddy in forum Kress Milling MotorsReplies: 6Last Post: 18-08-2010, 05:25 PM
  Does such a beast exist (using Z plane as manual-esque drill press)By HankMcSpank in forum Computer SoftwareReplies: 0Last Post: 04-03-2010, 05:36 PM
