    Asto should not make a lot of difference, most of the connections and settings are the same across a lot of the different models. You have enough manuals here now to what you need. the only difference will be the frequency settings for the speed control which won't be hard to deal with. Post a pic of the one you have.
    Also i think the VC150 = Cub 1.5 amp version
    asto's Avatar
    Lives in Attica, Greece. Last Activity: 1 Week Ago Has a total post count of 68. Received thanks 1 times, giving thanks to others 0 times.
    Sure i will do that tomorrow
    Thank you all
    regards
  3. @swarfing Exactly so, I thought the Cub is the VC150 (except its not 1.5A but 1.5kW (2HP) LOL), IMO branded differently for different markets...
    Yes it is the 1.5kw Irving looking again. all config is the same as far as i can see on them all.
    Paul
  5. #15
    asto's Avatar
    Quote Originally Posted by Swarfing View Post
    Paul
ID:	8739Click image for larger version.
ID:	8740Click image for larger version.
ID:	8741Click image for larger version.
ID:	8742Click image for larger version.
ID:	8743Click image for larger version.
    I hope these IMO images have a lot to say.
    The schematic came out of the Parajust manual. The pdf extracts are for the Parajust
    As you all see, control impendance is double in the IMO as Parajust needs 5K pot in order to bring the motor to full stop.
Name:	Parametrics Instruction Manual IM6007 FHP Parajust_0006.jpg
ID:	8745Click image for larger version.
Name:	Parametrics Instruction Manual IM6007 FHP Parajust_0024.jpg
  6. #16
    Ok this is much older than what we have been looking at. But you have all the information to connect this up so don't understand your problem with it Asto? Swap the potentiometer out for a 10k one
  7. #17
    asto's Avatar
    You mean an external pot?
    With an external linear rotary pot of 10K runs fine.I've done this already.
    My problem is, that I totally disregard which way to proceed in order to alter settings that will cause the IMO find sufficient the Orac's 5K digital pot and bring the motor to a complete stop...Cause, when I deccelarate through the machines (-) button the control outputs a maximum 5K resistance. I really do not know if it is possible to alter this value to 10K.
  8. #18
    Maybe i am not understanding this completely. The wiring in the Orac should go directly to the VFD for the spindle control yes? or is it going by a different circuit first? Is the speed adjust from the software of the machine or just analogue control?
  9. #19
    asto's Avatar
    That's right Swarfing.
    The Orac's controller decides what resistance value to apply at the inverter input. And is wired directly to it even though the VFD may be removed and operate as stand alone to control motors of some other system.
    Even when the machine is at manual mode the controller does the accel/deccel i guess by digitally switching resistors internally. It has to be this way how else would it be!
    Is that the question or I have missed something due to the foreign language factor which applies for me here.
  10. #20
    Ok i understand now thank you. Does the machine speed controls ramp up and down linear or are there distinct steps in the ramping?
    My thoughts were that the speed pot from the VFD ran directly to the machine controls. I do not know this machine and find it difficult without seeing it. Could you do a pic where the wires go from the VFD to the machine controls?
  1. 1 3/16"-16 tap and die needed
    By dazza in forum Marketplace Discussion
    Last Post: 26-12-2013, 05:36 PM
  2. Help needed connecting IMO JAGUAR VFD to Orac
    By asto in forum Spindles & Drive Motors
    Last Post: 09-04-2013, 08:05 PM
  3. help needed going to the next level
    By luke11cnc in forum Computer Software
    Last Post: 20-09-2012, 08:53 AM
  4. help needed for .drg files
    By swinds in forum Machine Discussion
    Last Post: 22-06-2011, 09:18 PM
  5. WANTED: Needed for my build
    By jpcnc in forum Items Wanted
    Last Post: 08-01-2011, 02:22 PM
