OK yes I can see the advantage of this, especially on larger boards. for me it wouldn't be worth it, the only boards I do are 100x 100 max.
Interesting software though especially as it can do proper lathe threading.
Just my take on it compared to Mach is that in Mach we can have just what we want on a screen and a lot, in fact all the alternatives I have seen like this one and Berts offering is that they are written by programmers, not engineers or users and have screens full of blingJohn S -
12-05-2013 #2
The boards I make are typically even smaller than that - 70mm x 40mm ....I mill relatively small traces for SMD (SOT23-5 is as small as I go) & being able to probe is essentaial with a V cutter to get decent track width result.
Z Probing allows me to essentially disregard how flat the copper board is (& the inevitable clamping 'bow')...but more importantly I can disregrad how uneven the machine bed &/or spoiler material may be.Last edited by HankMcSpank; 12-05-2013 at 03:48 PM.
12-05-2013 #3
I only have art cam so I'm not sure how to import gerber files into it, I've done a google and its not much help, basically I have been creating a pdf bringing in the monochrome to artcam and converting them to vectors.
Ralph Waldo Emerson
12-05-2013 #4
gerber files are created by your pcb design software.....what are you using to design the pcb? (I'm not familiar with art cam...cambam has a free trial period & can import gerbers)
12-05-2013 #5
Ralph Waldo Emerson
12-05-2013 #6
If your using Eagle, you can use pcbgcode.ulp to create the necessary drill files as well as the router isolation files.
Art
AKA Country Bubba
(Older than Dirt)
What tooling to drill lots of 10mm holes 45mm deep?
By AlanMJackson in forum Tool & Tooling TechnologyReplies: 24Last Post: 13-01-2014, 08:53 PM -
Drill 4 x 28mm holes through 44mm thick aluminium
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 30-09-2012, 09:17 AM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
