    Nugget i think you need to read the whole thread.....Welcome by the way.
    Quote Originally Posted by Swarfing View Post
    I agree. I would also like to say that the idea was to design a "starter" machine that would encourage "would be cncer's" to take
    their first steps into the wonderful world of cnc. G.
    I think the purpose of a starter machine is to:
    1) provide a machine which is known to be fully compatible and working.
    2) be cost effective
    3) require minimal skill level
    Suppliers, materials and software need to be specified to guarantee compatibility.
    The machine should not be over-specced and all parts should be fully utilised.
    Precision parts should be bought off the shelf with the only fabrication requiring basic hand tools where possible.
    Like so many people state on here - you need to specify exactly what your goals are before you can hone in on the solution.
  4. The Following User Says Thank You to Spedley For This Useful Post:
  5. #4
    I don't think it matters what your goals are, there will always be too many of them for a group project.
    The thread is 6 months old now and so far has got nowhere and sorry to say this but it never will.
    Only way a machine will get built is if one person decides to build what 'he' thinks is right and offers it for sale.
    Then all the cheap arsed vultures will gather and pull holes in it and reckon it's too expensive and you could do it cheaper.
    However missing the point that they are still weld to the fence, not sat on it.
    John S -
  6. #5
    John, I agree with most of your sentiments, and the idea was never to try to "design a machine by committee", merely to come up with a set of general parameters for a starter machine and then for one person to "run" with it. There are certainly enough people on this forum that could do that if they wanted to.
    Of course there would be critics - does that really matter? This thread has been dormant for the last six months just because
    of such comments, and I only reintroduced it because there have been several posts from people asking about about small starter machines/kits etc. G.
  7. #6
    Quote Originally Posted by GEOFFREY View Post
    So what parameters would you suggest? Lets see if 1% or 2% of people agree with them...
    Tempting...
    I will post the drawings for a medium size machine I've designed soon, but I doubt anyone would use them since you can't make it without a milling machine & CNC router & lathe, which is likely to be a problem with any general design people come up with here.
  8. #7
    If you can minimise and simplify the pieces requiring milling/turning then these could be supplied by people on the forum. I often reads posts on here where people are asking for parts cut, why not pre-defined parts for the cnc machine?
  1. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  2. BUILD LOG: My first project: A fast router...
    By Boscoe in forum DIY Router Build Logs
    Last Post: 14-08-2013, 09:34 AM
  3. Project CNC Router for all
    By Anónio Pinho in forum Open Source Designs & Plans
    Last Post: 30-06-2012, 01:31 AM
  4. NEW MEMBER: New to MyCNCuk
    By m1ptr in forum New Member Introductions
    Last Post: 28-03-2012, 02:47 PM
  5. Replies: 1
    Last Post: 01-01-2012, 12:34 AM
