Just use an end mill saller than 1.5mm and cut a circle - any dia you want!!! G.
04-07-2013 #2
04-07-2013 #3
A 1/16" drill is a tad smaller than 1.6mm. Using a knurling tool on pins, shafts, axles etc is great for making them grow a bit - almost the proverbial 'putting on' tool. A straight knurl is good in some dry applications whereas a diamond knurl may help hold the glue as a shaft is pushed into a hole.
The usual way to get a hole bang on size is to drill undersize and then ream it.
Reg
04-07-2013 #4
Some drills will cut under size, it usually depends on how they are ground. Cheap drill bits are often slightly under. With plastic, if you drill it at a slowish speed and high feed (thus avoiding the drill from spinning in the hole for too long) the plastic will usually "stretch" slightly and produce a hole slightly smaller than the drill bit dia. The other option is to drill something like a 1.5mm hole, heat the pin to around 150C with a paint stripper and push it into the hole. Experiment with offcuts first to get a feel for the best technique!
EDIT:
Seeing as you already have "snug" fitting holes, you could also give the end of the pin a light tap with a small ball pein hammer to make them slightly oval so they fit tighter.Last edited by birchy; 04-07-2013 at 08:53 PM.
cnc3040z-s probe and limit switche pins
By elvis in forum Motor Drivers & ControllersReplies: 7Last Post: 14-04-2013, 11:05 AM -
RFQ: 16mm long stainless pins with m5 tap
By dazza in forum Projects, Jobs & RequestsReplies: 12Last Post: 11-03-2013, 03:12 PM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM -
Dowel Pin Drill jig
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:34 AM
