09-07-2013 #9
There's 28mm between the base of the rails and the base of the blocks. 1204 ballbut is 25mm deep, but 1605 is a whooping 40mm, so I'd need 12mm more clearance, it's almost like adding an additional 12mm plate just to get clearance. How do people normally get around this? is it packers / pockets and double plates to get more clearance?
The bolt head can go from the top on both versions of the housing, it's an M4 bolt and I have 8mm clearance on top for the head. Standard head on a caphead M4 is roughly 7.2mm.
Regards,
dsc.
Plasma floating head...
By Davek0974 in forum Plasma Table MachinesReplies: 27Last Post: 01-01-2015, 01:52 PM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM -
Looking for a housing for your electronics?
By Smiler in forum Electronic Project BuildingReplies: 1Last Post: 01-09-2008, 07:38 PM
