  1. Yep - t'is cheaper...but more work involved in assembly.
    One more question while i'm designing...
    I've been thinking more about dual leadscrews with a single motor for the x-axis - what's the most cost effective way of doing this & a good place for parts?
    (looking more at costs rather than exact setup at the moment)
    Quote Originally Posted by CraftyGeek View Post
    Not has much work has you may think, profile still has to be drilled, tapped etc and it's not always easy has folks think it's shitty stuff to drill and even worse to Tap good threads into.!
    The best way is to use 15mm HTD timing belt and pulleys running around 2 idle bearings to central motor.
    Your local bearing company may be the best place to ask, I use lots belts & pulleys and this what I find cheapest. . . . But failing that then there's likes of Bearing boys etc on-line. If you look around the forum others have posted links to places they've bought.
  1. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  2. FOR SALE: 25mm Linear Slide bearings
    By D-man in forum Items For Sale
    Last Post: 28-11-2010, 05:14 PM
  3. Calculating forces on linear bearings ...
    By Jonathan in forum Rails, Guideways & Bearings
    Last Post: 24-11-2010, 02:26 AM
  4. Anybody used these linear bearings before?
    By pjl83 in forum Rails, Guideways & Bearings
    Last Post: 08-06-2010, 12:42 PM
  5. Play in linear bearings
    By leadinglights in forum Rails, Guideways & Bearings
    Last Post: 01-05-2010, 05:01 PM
