Thread: Several mild steel parts
22-08-2013 #2Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
24-08-2013 #3
25-08-2013 #4
Looks to this layman like a fine result in double-quick time Ian.
I would imagine that dudz will be well thrilled with this progress!
26-08-2013 #5
Very Impressed with the quality and time it took (or did'nt take) to make these bits. I shall put more work your way Ian.
ThanksSwedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM
