  1. Hers something we have been CNC machining lately its a jig for building bicycles on:
ID:	10174Click image for larger version.
ID:	10175Click image for larger version.
    very nice compo,is it a customer job or do you build the frames also?
  3. Quote Originally Posted by deisel View Post
    We build bicycles too, its nice made the switch from industry to doing this
    Huh that fixture table looks expensiveeeee and I bet those Jigs weren't done on a Diy build. . Lol
    What coating did you put on those nice shiny tooling plate jigs.?
    any chance of a photo of a bike in a jig?
  6. Quote Originally Posted by jcb121 View Post
    At this time , being honest and because i have been told to keep it on the downlow unfortunately not the jigs are made for the bike manufacturer im working for ,no leaks, but i will post some for you when i get given the secrets out
  7. Quote Originally Posted by JAZZCNC View Post
    Hey Jazz its an optical alignment table your quite correct , they were done on a hurco
    I am designing some cnc controlled fixtures and machinery though for the shop but without an industrial cnc its kind of hard to make them
    Its simply hard ano with a coating called marbocoat applied after to stop epoxy and the like adhering
    Do you mind revealing what cutters you used to get the seemingly good finish?
  9. Quote Originally Posted by Jonathan View Post
    Jonothan
    i use the aluminium specific WNT milling cutters any aluminium specific cutter will give you a pretty nice ,they eat material though you have to be careful at your ramp in when side milling as they like to take a big bite they supply the place i used to work AMRC | The University of Sheffield Advanced Manufacturing Research Centre with Boeing the fancy finish on the tooling plate is just standard mic 6 the actual face mill they use is a PCD insert on a 1.6m dia face mill ,
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 17 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    Is the jig for assembly/bonding carbon fiber components, will the bikes be made in the UK.
    Mike
  1. Clamping Jigs
    By Washout in forum Tool & Tooling Technology
    Last Post: 03-03-2014, 09:54 PM
  2. RFQ: Ambitious Bicycle build project needs help
    By Psycholist666 in forum Projects, Jobs & Requests
    Last Post: 16-03-2013, 12:10 AM
  3. copying jigs on a cnc
    By crossleymarko in forum Machine Discussion
    Last Post: 06-04-2012, 09:35 PM
  4. Vid - Handbuilding a bicycle frame
    By m_c in forum General Discussion
    Last Post: 04-02-2011, 01:24 AM
  5. 8020 Bicycle
    By Lee Roberts in forum General Discussion
    Last Post: 08-05-2009, 07:03 PM
