03-11-2013 #9
Either is plenty stiff enough. Sometimes people go for the 20mm rails just to make it easier to to make the parts they mount to with minimal machining. You need to draw it and work out which is best before buying them.
Don't get those. They're 3A/phase which means they're the higher inductance motors. You want motors with lower inductance to get more torque at higher speeds - just search this on the forum and you'll find more detailed explanations. Last time I checked, these were the best value.
HTD 5m (i.e. 5mm pitch) and 15mm belt width. Don't get bigger pulleys than you need to as it'll adversely affect the acceleration. You can get them from Bearing Station, belting online or aliexpress.
The 'digital' ones should be better than the 'analogue' ones, but it's a bit of a misnomer as they're all digital to an extent. Drivers like the AM882 use better algorithms (e.g. field oriented control) to get slightly higher torque from the motors and detect stalling, among other things. However once you've tuned the system properly it wont stall, so if you can get enough torque with a cheaper driver (e.g. DQ860MA) I see no reason to get the better ones.
The Following User Says Thank You to Jonathan For This Useful Post:
Leadshine website and AM882
By EddyCurrent in forum General ElectronicsReplies: 12Last Post: 24-08-2018, 01:59 AM -
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
AM882 works with Protune - but not with the ZPA5-INT BOB
By badgerman in forum Motor Drivers & ControllersReplies: 19Last Post: 01-09-2013, 09:44 PM -
Problem with AM882 drivers !..... or it could just be me !
By Buba b in forum Motor Drivers & ControllersReplies: 10Last Post: 03-04-2013, 09:28 AM -
AM882,s and Mach3 ......plus hair removal !!!
By Buba b in forum Motor Drivers & ControllersReplies: 3Last Post: 26-10-2012, 05:11 PM
