Thread: Ready Steady Eddy
15-11-2013 #10Unlikely to cause significant damage to your limbs due to spindle's low inertia, so personally I'd rather it damaged the limb as that'll get fixed for free on the NHS, unlike the VFD.
Originally Posted by EddyCurrent
Vaguely.
If you remove the power, the inverter can't do anything as it will only remain switched on for less than 1/10th of a second before the capacitors discharge. So no, it wont apply the brake.
In that case you need to separate 'fault conditions' from safety concerns - e.g hitting a limit switch or stepper driver fault signals do not pose safety hazards, so treat them as such and wire it so the machine just pauses. The only one that warrants fast and complete shutdown is pressing the e-stop, as that's what you can supposedly do if you're about to get hurt.
The signal should be wired such that if the wire's broken or otherwise interfered with the signal changes state and the system stops. The VFD going faulty sounds exceptionally unlikely, but if you're worried about that then just have a timed relay to switch the VFD power off a couple of seconds after the signal (as mentioned earlier), since by that point the spindle will have stopped so you wont damage the VFD by cutting the power, and if it's not stopped then the VFD has gone faulty so you probably don't care about risking damage to it by cutting the power.
My new spindle takes 107 seconds to stop from full speed if left to coast. I tend to agree that it's not really a problem though.
Two, see above. You could take advantage of the enable signal on the stepper drivers to disable them, then link cutting the power to the delay associated with the VFD.
Yes - the internal resistor is sufficient to stop the 2.2kW spindles in less than a second, so you can easily implement the above method.
(3000th post...
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
