Thread: Ready Steady Eddy
Good stuff EddyCurrent, I'm still working my way through your diagrams trying to fully understand :) - Do you have any provision for activating your estop circuit from the controlling software? I suppose the argument could be made that its not needed unless the pc a distance from the machine?
I have just acquired 10 of these from a control panel I stripped down (7x 24v and 3x 230v) which seem to be a similar spec to yours:-
Finder TYPE 55.34
The 5A rating, is that for the entire relay or for each contact?
There are also 4 contactors which I haven't taken out yet. Are there any practical/safety differences between a relay and a contactor?Last edited by cncJim; 19-11-2013 at 06:39 PM.
19-11-2013 #2
Yes that's what the Charge Pump relay is doing. The BOB is turning a 12khz signal from Mach3 into a 0 or 5vdc output, on my particular BOB the output of ENA is 0v when Mach3 is healthy and +5v dc when it stops.
Those look just right, I looked on Farnell and they appear to be 4 pole Change Over which is what you need if using my diagram, the 5A rating is for each contact.Last edited by EddyCurrent; 19-11-2013 at 09:39 PM.
19-11-2013 #3
19-11-2013 #4
With electrical systems there are generally two main circuits, the 'control circuit' and the 'power circuit'. Contactors are regarded as components of the power circuit whereas relays belong to the control circuit, it's mostly to do with the current carrying capacity and the ability to break that circuit without arcing or at least controlling the arcing. There are relays with positive guided contacts and these are for use in safety circuits, I have not come across equivalent contactors but that's not to say they don't exist. I'm not 100% on this but I think relays originated in communications areas such as telephone exchanges. Contactors can have auxilliary contacts fitted which in essence are relay equivalents and are used in the control circuits for those contactors.
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
