Thread: New spindle needing new mounts
02-12-2013 #6
Ye thought about scanning the gauge, might be the easiest option.
So Jazz what your saying is put the spindle in the middle of the bed, insert a piece of steel, say a 6mm rod as that will probably be the max shank size. Have this steel rod go down to the bed and bend 90deg and run parallel to the bed, touching it. If its square then the rod should stay flush to the bed along its length, and while I spin it around the bed 360deg..?
RFQ: Ballnut Mounts needed.
By dudz in forum Projects, Jobs & RequestsReplies: 1Last Post: 05-03-2014, 09:01 AM -
Needing advice on linear rail blocks
By oldmam4m80s in forum Rails, Guideways & BearingsReplies: 0Last Post: 27-10-2013, 07:57 AM -
RFQ: Nema 23 motor mounts
By luke11cnc in forum Projects, Jobs & RequestsReplies: 14Last Post: 06-10-2011, 02:21 PM -
Mounts; Motors, bearings etc..
By mocha in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 29-09-2011, 10:20 AM -
FOR SALE: MDF NEMA 23 Motor mounts
By Tom in forum Items For SaleReplies: 40Last Post: 21-08-2010, 01:23 AM
