  1. #21
    I am at the point of buying the same servos. At the manual it states it works both on one phase and 3 phase, but nothing more. By the way if you don't have the manual i can mail it to you.
    I will follow how this develops, hopefully it will work.
  2. #22
    vre's Avatar
    Lives in Athens, Greece. Last Activity: 19-05-2022 Has been a member for 9-10 years. Has a total post count of 39.
    please send me (check your pm)
    thank you.
  3. #23
    Hi just send you the message with the manual. I believe there is should be enough capacitance and the drive to be prepared for the single phaze.
    Look at the snip from the manual below and from another similar Chinese drive:
Name:	servo 220v 1.JPG
ID:	11086Click image for larger version.
Name:	servo 220v 2.JPG
ID:	11087Click image for larger version.
Name:	servo 220v 3.JPG
    It seems the connection should be between L1 and L3/ judging from 3rd picture where they are named R and T/- i mean the phase and the middle one to be 0.
    But dont trust me on this, just open it and see whats there and think
  4. #24
    vre's Avatar
    Thank you!
    Ιam searching 2 days and i haven't found it!
    Where you found it ? respect!!!!!!!!!!!!
    I have also read (in chinese with translator) that these drivers is imitated (good imitation) but which is the original to download manual in
    English from original manufacturer ?
    Some photos of this drive:
    (You can see the big smoothing caps, the 2 rectifiers which are down from caps also you can see that pcb supports
    CN1 connector but missing this connector and some smd components near it.
    I believe that is rs232/485 connector. Has someone schematic to add the extra components ? )
ID:	11092Click image for larger version.
ID:	11093Click image for larger version.
ID:	11094Click image for larger version.
ID:	11095Click image for larger version.
ID:	11096Click image for larger version.
ID:	11097Click image for larger version.
ID:	11098Click image for larger version.
ID:	11099Click image for larger version.
ID:	11100Click image for larger version.
  5. #25
    Fred from BST automation / Aliexpress/ send it to me as i am at the point of buying from him the major mechanical and electrical components.
    I am not sure but it seems from the 1st photo that L1 and L3 as i suggested are where the phase will go, judging from the fuses. But when in doubt i go to a local electronic repair shop and for 1 min the guy solves my doubts with advice, so that will be the wise choice to do.
    I believe they should be Mitsubishi most possibly. But- bear in mind that every copy is a thing on its own, just use the manual i send you. yeah, i know, the crappy Chinese English translation.
  6. #26
    vre's Avatar
    Thank you i will check it.
    Look and other sellers BST automation is not the cheaper...
  7. #27
    Quote Originally Posted by vre View Post
    You are wrong there. Dont look only the prices stated there. He is the one of the cheapest and very reliable+ speaks good English. He and Chai from linearmotionbearing . He gives extremely good prices for ball screws and rails, especially if you buy all from him. and there is a great choice. One very important thing is that he can provide almost anything you see on Aliexpress, just ask him. And is speedy with the answers.
    For now he is my best choice of supplier from China.
  8. #28
    vre's Avatar
    I followed the pcb traces in AASD-30 servo driver and made a simple schematic
    Also in CN1 connector the missing components are:
    R78
    R79
    R80
    R132
    R134
    R135
    R136
    R137
    R139
    C65
    C66
    C67
    C68
    C69
    C70
    C106
    D11
    D12
    Z1
    Z2
    U22 -> 16 PINS
    U35 -> 8 PINS
    CN1 -> 6 PINS
  9. #29
    Quote Originally Posted by rnr107 View Post
    Now, there is nothing in there requiering a phase shift between the 3 phases coming in....all the bridge rectifiers care about is 240V AC...
    So, I decided to connect Neutral, Live, Live where the 3 phase were supose to go (L1, L2, L3)... This way the load is spread over the 2 briges as per 3 phase setup.
    Tryed that this morning... All good! Motor happy, drive happy... (all stays cool )
    Laurent
    R78
    R79
    R80
    R132
    R134
    R135
    R136
    R137
    R139
    C65
    C66
    C67
    C68
    C69
    C70
    C106
    D11
    D12
    Z1
    Z2
    U22 -> 16 PINS
    U35 -> 8 PINS
    CN1 -> 6 PINS
    Not that i am an expert, but common sense tells me that by the way Lauren connected his drive he achieved nothing more than using only 1 rectifier, assuming his drive has similar schematic.
    From what i see the way to use the 2 rectifiers will be to connect /phase and ground/ to each rectifiers 2 legs /s and s / in parallel which means the rect 2 s and s inputs MUST be un soldered or the path cut with exacto knife so that they are not together
    It probably will work without problem with 1 rectifier.If is not possible to unsolder the rectifier legs or split the path with exacto knife, having in mind that on ebay are selling big heavy duty rectifiers for dirty cheap, just 1 bigger rectifier and forget about connecting the second.
    PS. Dont mess adding components, what is written on a board and is missing, does not mean you can add it without understanding what you are doing.
  10. #30
    vre's Avatar
    The pcb over the rectifiers has some ceramic caps as shown in photos. So its probably better to not modify the pcb.
    I will check what these small ceramic caps do...
    I think (please correct me if iam wrong) that if you bridge 2 ~ of 1st rectifier (means to bridge L1 with L2) and connect phase/neutral to L1-L2/L3 i think all diodes (8 from 8) used without modifying the pcb.
    To understand why this happens see following the image
    (In second rectifier the 2 ~ are allready bridged so you must bridge the 2 ~ of first rectifier to make all diodes to work with single phase 230VAC)
    I will check with oscilloscope if the smoothing in single phase is ok with default caps and if the driver need more caps for smoothing...
    I have tested the servo motor/driver with phase/neutral connected in L1/L2 and L3 unconnected (using only 1 rectifier) and seems to working.
    To use 6 diodes from 8 totally with this type of pcb wiring you must connect phase/neutral to L3/L1 or L3/L2 because the in 2nd rectifier
    the 2 ~ legs are bridged. With phase/neutral to L1/L2 only 4 diodes of 8 used.
    I have understand what missing components do. They are very cheap and i can't undestand why the manufacturer did not added them to give rs232/485 communication port.
    The question is if LCMXO640C-3TN144C chip supports rs232/485...
    Iam not having schematic for missing components but i found what they do.
    U22 is a max232 ic (for rs232) and u35 is a sp485 ic (for rs485) 6 pin cn1 connector is a mini 6pin din ( PS/2 ) connector witch provides rs232 & rs485 connection.
    I have downloaded the datasheets of these ics (show in example circuits adjacent components values) and followed the traces in pcb and from that i read in manual you send me i beleive that i would find the extra smd resistors/caps/choke coils/diodes.
    I have already ordered from ebay max232 & sp485 also i have oscilloscope & some spare smd resistors/caps/chokes/diodes so i would try
    to add in this servo driver serial communication port.
    The is no risk to burn some critical because D11 & D12 missing diodes is for protecting the LCMXO640C-3TN144C chip.
  1. Replies: 2
  2. What size servo motor do I need.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 31-03-2014, 09:16 PM
  3. 2.2kw servo motor for spindle
    By blayde in forum Spindles & Drive Motors
    Last Post: 01-01-2014, 04:48 AM
  4. Servo motor sizing?
    By gavztheouch in forum Stepper & Servo Motors
    Last Post: 18-04-2013, 11:40 PM
  5. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
