    Does not matter which Cam you use so long as you save the Tap file as G-code save to USB stick, then place into DSP select file, set machine parameters then run.
    Phill
    That may not be exactly correct.? . . The post processor will need to be correct and the DSP could need a specific Post.!
    I would hazzard a guess that it just use's standard G-code so most basic Post's like for Mach or Linux cnc would work but it could also need specific Headers etc to set the DSP up.? . . . The manual should tell you.!
    The DSP uses "G-Code (mm) (*tap) files" created from most Cam programs, this has been by trial and error for me to say this, I did not find it in the manual.
    Inputting other Post's such as Mach3 tap files locks DSP up and mess's with onboard config files you then have to go down the "Update Auto System" reset route and setting all machine parameters up again, it's time consuming but do able.
    Another tip make sure the memory stick is formatted first and only used for transferring files to DSP.
    Phill
  1. DeskProto 3D cam software, forum support added!
    By Lee Roberts in forum DeskProto
    Last Post: 27-01-2014, 03:21 PM
  2. Replies: 7
    Last Post: 20-01-2014, 08:55 PM
  3. Replies: 2
  4. HME Technology router NEE AMC-E controller WinAMC software
    By artmin in forum Motor Drivers & Controllers
    Last Post: 24-01-2012, 11:29 PM
  5. NEW MEMBER: Newby with Software questions
    By soupsy in forum New Member Introductions
    Last Post: 18-03-2011, 12:19 AM
