    No, I am getting the OX Plus, it has a cut area of 1200x580
    Quote Originally Posted by picyman View Post
    I couldn't see the plus model for some reason, anyway that size bed will be fine however I didn't comment on the machine itself but totally agree with the other posters. I can't see it whizzing a 1/2" cutter round a guitar profile in hardwood.
    Sorry to say this but I wouldn't turn that machine lose on an expensive piece of hardwood because there's a high chance it will wreck it.
    Like someone else lower down says it won't last very long and will soon become baggier than Grandads Y fronts.!!
    The fact it use's plastic rollers in profile slot ensures it's doomed from day one, those rollers are meant for sliding doors not CNC machines.
    The Z axis will bend like a banana with only slightest cutting forces and will flex badly giving a very poor finish in any thing harder than Balsa wood.
    If it's possible to return then I suggest you do so ASAP because it's completely inappropriate for cutting guitars.
    If you do keep it then Don't buy the Am882 has they are completely OTT for this small machine.
    This will be much better suited, still uses digital drives that are rated to 60V and comes complete with built in breakout board and Spindle speed control, thou this won't control Kress speed but will turn ON/OFF.!. . . . Just add power and your good to go.
    MX3660 - 3-Axis DSP Based Digital Stepper Drive Max 60 VDC / 6.0A
    Sorry to be Negative about your new purchase but it's a lemon for any decent quality work.
    Info on the Vslot stuff What is V-Slot
  1. NEW MEMBER: Newbie in reading
    By Mougli in forum New Member Introductions
    Last Post: 03-02-2013, 05:30 PM
  2. NEW MEMBER: Hi from Reading
    By Saracen in forum New Member Introductions
    Last Post: 26-11-2012, 01:50 AM
  3. NEW MEMBER: New member from Reading
    By madd in forum New Member Introductions
    Last Post: 04-12-2010, 01:33 PM
  4. Reading and fixing Chinese scales
    By irving2008 in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 10:35 PM
  5. Any old Draftsmen reading this?
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 18-12-2009, 11:14 PM
