Thread: Setting my table up...
Just checking. It seemed 4500-5000 was being stated as some general maximum - which as you know is not the case.
50A - at home - see the street lights dim when you start that puppy
23-02-2014 #2
23-02-2014 #3
Just don't turn on the radio at same time hey.!!.. . . Lol
Next to me is a Sub station and you should hear that sucker buzz when me and my lad are on full tilt. . with 2 welders going at same and all other kit in workshop.!!. . . . . . Just hope the Elecy board don't spot the Cable running thru back wall of Station. .
23-02-2014 #4
He he, that's the way to do it ;)
nah, worst it can do is pop the breaker to the shop, if it does and likely will, I'll have to rewire and uprate the breaker, I'm pushing my luck well into the realms of stupidity as I have the shop running on a 32A breaker and intending to use a 2hp compressor, 6 fluorescent lights and a 32A plasma cutter :)
luckily the the cutter can be run at lower power on thinner stuff, but I am expecting to rewire soon.
04-03-2014 #5
New torch and psu arrived today, this thing is a beast!
not had a chance to power it up yet as I need to make a torch holder to fit the massive machine torch it has.
The tip is totally different to my smaller unit, must be half a pound of copper in the tip :o
Hopefully get the table cutting this week.
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
setting up a business
By dstivens in forum Opportunities Available & SoughtReplies: 5Last Post: 16-05-2013, 10:28 PM -
setting the origin
By Fivetide in forum Computer SoftwareReplies: 9Last Post: 04-02-2013, 12:18 AM -
hi i nead help please with setting up dsp control
By cockneyrebel in forum Machine Control SoftwareReplies: 1Last Post: 19-01-2013, 01:18 AM -
Setting up work on the rotary table
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 09-01-2010, 10:27 AM
