Thread: Making the frame square
One corner was 3mm lower than the other because I just started building from the garage floor assuming it was level.
08-03-2014 #2
Ah I see so you effectively put it in twist. But ounce positioned the epoxy will have levelled this out for you won't it.
That's a good point for Rob and others thou because while it may be obvious to others not everybody thinks that you need to start building from a FLAT level surface. It often pays out to spend a little time making a platform to work from or spend the time setting the bench level.!
08-03-2014 #3
08-03-2014 #4
Good That's why I like the top rail adjustable, yes it needs to be done right and takes a bit of time but gives that flexabilty if or when needed. Said it so many times but I'll say it again it's that important I feel.!! . . . Adjustment is the KEY to successful DIY machine.!!
engineers square - recommendations
By dsc in forum Marketplace DiscussionReplies: 0Last Post: 09-06-2013, 08:13 PM -
WANTED: Head Tram Square
By dudz in forum Items WantedReplies: 5Last Post: 31-03-2013, 01:03 PM -
Square Ballnut??
By Ricardoco in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 29-06-2012, 10:32 PM -
WANTED: 10mm think square of aluminium?
By Tenson in forum Items WantedReplies: 2Last Post: 08-06-2012, 12:42 PM -
Getting everything square
By daveshorts in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 31-01-2010, 11:21 AM
