Thread: Laser cutting Machines
the same one I linked to, but I went through ebay.
I am prepared that I might have to tweak it etc... but as long as it's all there and all the electronics and tube works I'll be happy.
I think for double the money, you would get the same machine, but a better build quality.
07-05-2014 #2
07-05-2014 #3
Ahh right, well I dont know about double the money you would more than likely get a more powerful tube and so on, you seem happy enough to give it a try, I know John S purchased one rather than build one.
Not sure regards build quality or what you are really referring to, i.e component quality over actual construction quality, from what ive seen there doesn't seem to be much to these machines, I dont think there is really much going on in terms of forces applied when cutting so mechanical requirements can be quite modest in comparison to lets say a moving gantry type machine people typically build.
When I had a little look at what diy options there was at the time I came across this website: http://www.buildlog.net/blog/2011/02...net-2-x-laser/ it looks like a nice little unit, though you do need to source your own tube if I remember correctly, I think he says something about shipping on tubes being to hit and miss to feel comfortable selling them and so on. I know they pop up on the bay now and again and I'm sure our Asian friends will have a steady supply up for grabs.
I think there is also quite a choice when it comes to the mirrors these machines use, so again if you want to invest in decent ones you can do, probably comes down to spend again though.
O, something else on the tubes...I didn't realise but they degrade over time (hours used), I think they need to be re gassed after so long, something that put me off a little and to think about.
Regardless though, sometimes its a better choice just to pay the cost rather than go diy so I can understand your decision to purchase instead.
Good luck with it anyway, I look forward to seeing how you get on :).
.MeLast edited by Lee Roberts; 07-05-2014 at 05:57 PM.
.Me
The Following User Says Thank You to Lee Roberts For This Useful Post:
RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
By nobby in forum Projects, Jobs & RequestsReplies: 0Last Post: 29-04-2014, 12:36 PM -
laser cutting ally plate
By i2i in forum Tool & Tooling TechnologyReplies: 12Last Post: 21-02-2013, 08:47 AM -
Laser cutting 10mm acrylic?
By camhguh in forum Laser Machines & BuildingReplies: 14Last Post: 04-09-2012, 12:51 AM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
For cheap cutting and engraving machines
By Tomas in forum Tool & Tooling TechnologyReplies: 0Last Post: 23-08-2011, 08:48 AM
