Hi Jazz
Thank you for that, but unfortunately that did not work.
10-05-2014 #2
Think you best explain again the problem because changing the keys would change the direction unless you didn't apply the changes by clicking ok.?
The other thing to try and really what you should have done instead of changing the X motor active state is to use the Reversed option in the Homing/limits. So set the X motor state back to previous state and try this and between this and changing the keys you'll get moving in the right directions.
Huanyang VFD control plugin for Mach3, USB RS-485
By JayPunchbuggy in forum Spindles & Drive MotorsReplies: 19Last Post: 15-05-2013, 08:00 PM -
2 motors on X how do I setup Mach3
By phill05 in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 04-02-2013, 09:33 PM -
Mach3 / Offsets / Tool setup etc
By dudz in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 20-11-2012, 03:51 PM -
New CNC Router Setup Tool For Use With Mach3
By CambiumMachines in forum Manufacturer NewsReplies: 3Last Post: 08-06-2012, 04:14 AM -
HID interface for remote control of Mach3
By Smiler in forum Electronic Project BuildingReplies: 0Last Post: 10-05-2009, 12:59 PM
