    thanks clive
    I didn't realise there were differences from one side of the bearing to the other so will have a butchers tomorrow.
    as is theres about 0.4mm of play.ta
    Have a look here, also the links in the post and other posts later on, you are not alone !
    http://www.mycncuk.com/threads/6565-...6128#post56128
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by deisel View Post
    thanks clive
    These are AC bearings and need to be orientated the correct way round the idea to shim them apart is to be able to give a little pre-load. 15A fuse wire is about .6mm and acts like a shim.
    I can not take credit for this tip as I have learnt it from higher up the food chain!! ..Clive
  1. What is the best way to mark out for bearing blocks and linear rails?
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 18-05-2014, 02:08 PM
  2. Bearing Blocks
    By GTJim in forum Rails, Guideways & Bearings
    Last Post: 15-01-2013, 07:18 PM
  3. FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
    By Jonathan in forum Items For Sale
    Last Post: 06-11-2011, 05:26 PM
  4. FOR SALE: 25mm round rail bearing blocks
    By D-man in forum Items For Sale
    Last Post: 31-10-2011, 09:26 AM
  5. Should my Z axis have a little play in it?
    By Philly in forum Gantry/Router Machines & Building
    Last Post: 29-04-2011, 04:28 AM
