Thread: GRP/Fibreglass info needed
06-08-2014 #18
Not even sure that is true Irving. Obviously it depends on wind direction and strength, but according to Bernouli, (can't remember spelling) wind blowing between the surfaces will cause a reduction of pressure on the underside, so in some instances will actually create negative lift (downforce). Anyway that is all academic - try to pass all responsibilty on to the installer!!! Good luck. G.
Pilz Relay info
By manofgresley in forum General ElectronicsReplies: 5Last Post: 08-05-2014, 10:16 PM -
NEW MEMBER: Hello from Ireland..........Need info....
By aquila787 in forum New Member IntroductionsReplies: 6Last Post: 10-09-2012, 10:09 PM -
BUILD LOG: second build, thanks for all the info.
By tonyken in forum DIY Router Build LogsReplies: 14Last Post: 11-04-2012, 10:32 PM -
Software info
By Web Goblin in forum CAD & CAM SoftwareReplies: 5Last Post: 09-01-2011, 05:41 PM -
Info on V23
By m.marino in forum CAD & CAM SoftwareReplies: 1Last Post: 14-10-2009, 09:18 PM
