29-08-2014 #4
Thanks Jazz for the advice.
I set a 19mm sacrificial board on the machine today and on top of that I set a small 200 x 120 x 13mm thick piece of ply
After setting the machine to "HOME, I then, using my procedure above, brought the arm axis's to the centre of my workpeice. Positioned the cutter to the correct marked centre and zero'd X & Y.
Then I brought the head down and jogged until the cutter (A 3mm dia single flute end mill) just touched the surface and zero'd Z
In my V Carve software I set the XY to centre of the work, and the height of the material as 13mm. Reference start for Z axis was top of workpiece at centre.
When I started the machine and set it all in motion the X & Y axis travelled to the exact set point in the middle of my piece as expected, but the Z rapid plunged into that point to the collet nut depth ! (Until I hit the E Stop button)
What did I do wrong? I'm missing something here and feel a little dumb.... Newbie cock up I know... Loooong time since I did this and it's a fun learning curve againIf you can't fix it with a hammer you've got an electrical problem !
Opensource machine for dedicated soft tooling?
By gavztheouch in forum Moulding MachinesReplies: 3Last Post: 10-02-2014, 10:27 PM -
Initial thoughts on new build
By Neale in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-01-2014, 11:05 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
Best Type of Machine to Build?
By Kevin in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 05-08-2009, 02:50 PM
