Why don't you router guys use comp air drives ? With the Desouter one I had which was very light, you could with a 1/8th carbide burr hold a piece of mild steel in one hand and cut through it. The exaust whilst a bit noisy could be used to blow swarf away. Phil. :idea:
20-07-2009 #2
20-07-2009 #3
What about these for PCB drilling / routing?
http://www.slidesandballscrews.com/b...tors-c-75.html
Some have integrated electronics, and some are high speed and are continuously rated.
We also have torque curves.Visit Us: www.automationshop.co.uk
21-07-2009 #4
All good stuff but it is speed I am looking at. A Dremel tops out at 33,000 rpm, no load, and I consider that a little pedestrian.
Ok so gear things up but using something like belt drives at high rpm involves tensioners and even then at high speeds perceived internet wisdom seems to think that belts stretch, slip, burn out, skip out of grooves, become unbalanced, 'become complicated'. Gears seem to suffer a similar perceived status of 'complicated'. At the moment my thinking is that direct drive is the way to go but I am still very much open to persuasion and/or reasoned argument
21-07-2009 #5
What speed and torque are you after?
the fastest we offer has a no load speed of 43000 rpm.
I have seen small motors run faster, but they were induction motors specially made for drilling applications like dental drills, but they can be expensive.
These were made by http://www.airbearings.co.uk and they can offer speeds of up to 300000 RPM.
but at these speeds expect to pay a lot and will also use air bearings
21-07-2009 #6
ultrasonic cleaners - cheapos good enough?
By dsc in forum Marketplace DiscussionReplies: 5Last Post: 23-07-2013, 11:54 PM -
Digital angle gauge
By njhussey in forum Tool & Tooling TechnologyReplies: 4Last Post: 04-12-2012, 08:07 PM -
Digital drivers from Zap
By Simon C in forum Motor Drivers & ControllersReplies: 5Last Post: 31-03-2011, 03:27 PM -
FOR SALE: digital vernier.
By i2i in forum Items For SaleReplies: 8Last Post: 13-08-2010, 11:31 AM -
Mill with digital scales
By Robin Hewitt in forum Milling Machines, Builds & ConversionsReplies: 14Last Post: 22-08-2008, 10:21 AM
