Thread: Heiz Machine Problem!
10-09-2014 #12D / 3D CAM Software and CNC controller: http://www.estlcam.com
10-09-2014 #2
Ah well you see then assumption at work again and I'm the ASS. I assumed you assumed so the assumption is you have Good point and fare Assumption. .
On another note I've just seen your Cam software and I like the look of it and may just give it a try as a companion for the Wood routers I build. I'm always getting asked if can recommend software.
Personally I use Solid Cam and i-machining so i'm very familiar with trochoidal milling so at the price your asking it's very impressive feature you have there. You do know that some folks around believe ROUTERS are can not supposed to be able cut steel let alone STAINLESS STEEL don't you.!! . . . . So this I like to see video very much. .. LolLast edited by JAZZCNC; 10-09-2014 at 11:05 AM.
DXF or machine problem, or neither !?
By Gasgasbones in forum CAD & CAM SoftwareReplies: 19Last Post: 29-12-2014, 02:59 PM -
NEW MEMBER: New to all this cnc stuff, looking to buy a Heiz machine
By cjohnh in forum New Member IntroductionsReplies: 10Last Post: 29-05-2014, 05:36 PM -
Location of machine problem
By Eugene in forum Computer SoftwareReplies: 2Last Post: 27-01-2011, 07:00 AM -
Finally got the bugger! (Heiz machine)
By scjb in forum Heiz CNC RoutersReplies: 3Last Post: 15-09-2010, 01:07 AM -
Machine problem. Heiz. Blew up on me !
By xchipx in forum Heiz CNC RoutersReplies: 2Last Post: 03-04-2009, 01:08 PM
