    Only Bleedin Obvious if you Bleedin know about it Robin! Bleedin hell man that's the Bleedin dumbest Bleeding thing I've heard you Bleeding say Ever.! .
    Well it might be, but there are numerous instances where people ask for information when a simple search reveals everything.
    Grow a sense of humour Eddy I was clearly having a Bleedin Joke.!! . . . . . . Clue was at the End. .
    Well, gavztheouch seems to have left the premises so we will never know if it was bleedin' obvious or whether I should have pointed him at the other one
    Cheers Robin, I have seen that site from a previous post you made on another thread. Ebay is also a good place to find parts for molds there are a few chinese sellers selling ejector pins, springs and bushings, I dont have a link but they should be easily viewable.
    Thanks for the heads up on purging deisel I was not aware of how toxic some plastics are when burnt or that you should not mix certain plastic together for safety.
    The rabit takes molds bases that can be made on the lathe ie. cyclindrical not square, at some point someone has modded the machine to also accept bigger square or rectangle molds. The machine came with a manual with some basic dimensions and mold making tips. I will try and scan some important pages and see if anyone can help me work out how to cut the injector gate on the rear of the mold.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    Any ideas on how best to machine this gate entry in the mold, the mold is cylindrical so I can use a lathe.
    I can see 4 components to the operation,
    1. 1.1mm hole
    2. 4mm radius
    3. 60 degree bore?
    4. 90 degree bore?
    ADD ME ON FACEBOOKS
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    CNC lathe would be the simplest.
    However, with a selection of drills, boring bar, 90deg countersink, and an 8mm radius ballend mill it could be acheived on a manual lathe.
    Hard to see what is going on, is this where a plasticiser nozzle connects to a mould parting line?
    I would not have thought it would be critical if there is no other inlet (insert "beats me, shrug" smiley here)
    Robin - This is a diagram of the nozzle/injection entry on the rear of the mold. The 'small internal cone' I think is hot metal cone that keeps the plastic from setting in the entrance to the injector point. Is this what you call a plasticiser?
    I think you are right that this is not so critical to get all the angles and rads just so. I think the only critical point would be the depth that the hot cone pokes into the mold specifically the 1.1mm diameter hole that feeds the mold cavitiy. If it goes in too far it will block the mold and if its too far away it might allow the plastic to set?
    ADD ME ON FACEBOOKS
  1. Plastic injection mold making forum?
    By gavztheouch in forum Moulding Machines
    Last Post: 13-10-2022, 11:31 AM
  2. New toy - Arburg injection moulder
    By Robin Hewitt in forum Moulding Machines
    Last Post: 26-10-2014, 11:59 PM
  3. RFQ: Any Injection Moulders on here, before I buy Chinese ?
    By Bazzer in forum Projects, Jobs & Requests
    Last Post: 18-05-2013, 11:25 AM
  4. DIY Injection moulding by JR Hartley.
    By HankMcSpank in forum Moulding Machines
    Last Post: 04-01-2013, 12:41 AM
  5. Proxxon MF70 for making injection molds
    By forrest in forum Moulding Machines
    Last Post: 11-04-2012, 11:30 PM
