Hank
If all you want to do is turn small pieces i would consider second hand. Save yourself a fortune. i have a tiny unitmat that will only take up to 20mm in the chuck that does well enough. Decent cutters and cooling (bucket, small bore hose and a windscreen washer motor with sponge over the end) is priority. The lathe you see there is the same as clarke, axminster and sealey in the same clothing. I must admit i do have a bigger lathe but by the time you buy all the other tools to go with it-----phew fortune blown.
08-07-2009 #2
08-07-2009 #3
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM -
Sieg Mini lathe - smallest diameter rod turn-able?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 18-11-2010, 01:15 PM -
Mini Lathes and their capability
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 8Last Post: 02-08-2010, 05:29 PM
