    Oh I see thanks for that. Would the ground be the tool and the plus the edge finder?
    sorry here is the link http://www.themakersguide.com/home/p...-edge-finder-2
    Most of all depends of your exact BOB. Whats yours? Usually on pin 13 directly if you have pull up resistor there. http://www.autoleveller.co.uk/cnc-probe-guide/
  3. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
    Quote Originally Posted by D-man View Post
    Yes but you don't always need the Gnd clip depends if machine/spindle goes to gnd. For safety sake your better using both.
  6. #4
    I'm using the uniport
  7. #5
    just reading your linksilyavski, is the resistor needed in my application?
  8. #6
    No, it says this in the uniport manual;
    "Either way you can wire switches between input and ground with no external component needed."
  9. #7
    you know, i keep forgetting to read that damn manual! guess i just like testing you guys haha
  10. #8
    Uniport works fine straight from the inputs I used one for 2yrs until it gave up the ghost. My famous Rupert Egg touch probe video was using the uniport.
  1. Torch Height control
    By Bobp in forum General Electronics
    Last Post: 09-12-2019, 04:46 PM
  2. uPVC CNC Corner Cleaner
    By StuH in forum Machine Discussion
    Last Post: 20-07-2013, 12:09 AM
  3. 1/4" / 6mm edge finder?
    By jcb121 in forum Marketplace Discussion
    Last Post: 18-03-2013, 02:58 PM
  4. Driver wiring to my computer for mach3 to control
    By AdCNC in forum Motor Drivers & Controllers
    Last Post: 01-04-2010, 12:27 AM
  5. Electronic edge finder: how do they work?
    By irving2008 in forum Probing, Digitizing & Scaning
    Last Post: 29-08-2009, 10:25 PM
