    I don't, I only have a demo of V Carve Pro, I was just pointing out that using the shortcut keys described by Earle, only the vectors rotate. You said the "the Vectors are the workpiece" which to my mind was not 100% correct because surely the material is part of the workpiece. Beyond that I care not a jot, I use F-engrave because it's free and does the job.
    The vectors are the workpiece that is the part you will cut and use, think of the "material" as your piece of paper you are drawing on, you only need to set the thickness of the material for the size of the part required.
    I can see why it's easy to think like that but No, the material is the stuff you are cutting, so it's the workpiece.
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    What if you're v-carving a rectangular workpiece? Rotating the vectors only will give you a very different finished workpiece.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Say you have a sheet of ply 8' x 4' and is the max of your machine bed 8' is in X axis but you want to V carve text to go across 4' Y axis you draw it in X axis and rotate and place in Y axis.
    You cannot rotate the "Material" as Eddy seems to think you can.
    Okay, this is my last post on this. I do not seem to think you can rotate the material. All I'm saying is two things;
    1. Only the vectors rotate when you apply transforms, the material does not.
    2. As I see it the material is part of the workpiece
    And lastly I don't have any problem with this, it's just the way it is.
    1. Only the vectors rotate when you apply transforms, the material does not. "Correct"
    read what D-man asked for in post 1 "Hey guys, I'm having a bit or a mate at the moment with the workpiece in vcarve pro outputting to the machine.
    for example if I want to cut along the Y on the machine I have to create my workpiece vertically in VCP
    any ideas
    I lied
    phill05, if I was cutting shapes from sheet material or stock that was well oversize for the job, it would not matter that only the vectors rotate.
    But if you cut like I do where the material profile is cut to size first on a saw, then clearly if only the vectors rotate they would no longer fit the stock material.
    I use CamBam mostly and it's the same with that, if I apply transforms the stock material is unaffected, so what I have to do is resize the stock to orient it in the other direction, i.e. swap over the X and Y values.
    Now all that is fine and I don't have a problem with that but what I am saying different to you is this, the material or stock in some instances, as above, is clearly the workpiece.
    I lied
    I guessed you would (smile)
    Eddy the question asked was how do I create my workpiece Vertically in VCP to which I replied, change workpiece orintation.
    Eddy It was your contribution that first saw light of Material: "I just tried Ctrl +9 45 left, Ctrl +0 45 right in VCarve, it rotates the vectors but not the material (workpiece stock)"
    Eddy I am working on different designs every day of many differnt sizes and the Vectors are my workpiece, I don't get to see a machine bed or get my hands dirty, I design and feed G code to 2 machines, I tell the guys 30 plus miles away from me in which axis to load the stone, power on and leave me to it.
    So could we both agree / disagree the we could both be right.
    Last question to D-man great you got sorted mate lets see some of your work now, and who looks the fussy twat now.
    Phill
  1. vcarve pro 7
    By GeoDurie in forum CAD & CAM Software
    Last Post: 22-05-2014, 02:46 PM
  2. Workpiece illumination
    By cropwell in forum Workshop & Equipment
    Last Post: 29-09-2013, 10:21 PM
  3. Securing the workpiece
    By jrob3rts in forum Machine Discussion
    Last Post: 16-06-2012, 10:21 PM
  4. Vcarve to Mach3
    By jcb121 in forum Vectric
    Last Post: 01-04-2012, 05:21 PM
  5. Workpiece hold down by glue
    By Robin Hewitt in forum Machine Discussion
    Last Post: 30-09-2010, 08:22 PM
