Thread: Vcarve workpiece orientation
30-10-2014 #2
The Following User Says Thank You to EddyCurrent For This Useful Post:
30-10-2014 #3
Eddy,
Why would you want to rotate the material? I am working every day like this, I set the Job "stock" dimensions greater than the model sizes and square, set the origin to centre, create the part I can then rotate to any angle with ctrl 9 and ctrl 0 then F9 to centre create the toolpaths and cut no problems whatsoever.
If I want a pair then copy and paste move 1 each side of centre.
If I was on txt same as above you can rotate, move, scale reverse, and only toolpath and cut what you want.
look at the time taken to rotate and screenshot only seconds.
30-10-2014 #4
I don't, I only have a demo of V Carve Pro, I was just pointing out that using the shortcut keys described by Earle, only the vectors rotate. You said the "the Vectors are the workpiece" which to my mind was not 100% correct because surely the material is part of the workpiece. Beyond that I care not a jot, I use F-engrave because it's free and does the job.
30-10-2014 #5
30-10-2014 #6
30-10-2014 #7
What if you're v-carving a rectangular workpiece? Rotating the vectors only will give you a very different finished workpiece.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
vcarve pro 7
By GeoDurie in forum CAD & CAM SoftwareReplies: 3Last Post: 22-05-2014, 02:46 PM -
Workpiece illumination
By cropwell in forum Workshop & EquipmentReplies: 0Last Post: 29-09-2013, 10:21 PM -
Securing the workpiece
By jrob3rts in forum Machine DiscussionReplies: 3Last Post: 16-06-2012, 10:21 PM -
Vcarve to Mach3
By jcb121 in forum VectricReplies: 6Last Post: 01-04-2012, 05:21 PM -
Workpiece hold down by glue
By Robin Hewitt in forum Machine DiscussionReplies: 2Last Post: 30-09-2010, 08:22 PM
